Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3531 Questions View all
screen is unresponsive to my touch.
Bought iFixit awesome kit for changing battery and followed the guide
Everything went on properly until I was about to reassemble connectors.
I lost the 1.3mm PH#000 and could not find it :=(
I reassembled without this 1 screw. After hard reset the display looks like this
No respons whatsoever. Could it be missing screw issue or have I damaged LCD?
Add a comment
1 Answer
Chosen Solution
Hi,
There could be many things wrong here but here are the main things that could have happened:
  • You haven't put the connectors in correctly, take apart the phone by taking the screen off (be sure to unplug the battery before getting into the phone) and then re-connect the connectors. Make sure they click in place
  • If that doesn't work it could be long screw damage. This is very nasty and happens when you over tighten the screws when you are putting the metal bracket back on. Did you hear any clicks when tightening?
Missing one screw wouldn't this however also putting the wrong screw into a different hole may cause long screw damage as well. When doing the first step and taking the bracket off, have a look at what screws are coming out of the holes. Have a look at the image below and you can measure the screws with a calliper to make sure it's the right screw
Score 2
4 Comments:
No clicks when tightening. I was very careful to put screws in proper place.
I try your 1st suggestion.
Btw, thnx for rapid reply. Awesome
by
Your 1st suggestion was correct, bad connection was the issue. Now I have a 5S in mint condition :=) it will last for another 5 years I hope!
Your answer saved my day, thanks!
by
Per, if this answer solved your problem, please “Choose as Solution”. This allows people in the future to understand which answers helped solve the problem and adds value to the site. - Thanks
by
Thought I did...?
by
Add a comment
Add your answer
Per Hansson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 107
