Released June 2012, Model A1278. Intel processor with Turbo Boost, Up to 512 MB DDR5 Video RAM
1080 Questions View all
What is customizable in the MacBook Pro 13'' Mid 2012 Unibody.
Hi guys,
I have a mid 2012 Macbook Pro 13'', which is already upgraded with 16gb RAM and 1Tb SSD, but I was wondering what I could do next to reach it's full potential. I actually don't want to pay for a new machine, and as I did not pay for this actual Macbook Pro, I think it would be worth the money to invest a little bit and upgrade it. Is it possible to change anything else, other than what I already did?
Thank you guys for your help!
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Chosen Solution
This is the machine that most of the people at iFixit use because of its repairability. It is also the machine I prefer along with the 15". The most common problem for slow down in it is the hard drive/IR cable. It gets damaged as it climbs over the top ledge and onto the optical drive. To protect it I use a thick padded tape on either side of the cable to prevent the bottom from impacting it. For a while Apple was offering free replacement of this cable. Check the part number on yours and go with the 821-2049. @danj can verify that part number.
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable Image
Product
$44.99
Score 1
Add a comment
Most Helpful Answer
It depends on what which model you have. If you have the low end model you could swap out the logic board with a high end model (2.5 GHz i5 Vs 2.9 GHz i7). It's a bit of work but thats about it.
MacBook Pro 13" Unibody Mid 2012 Logic Board Replacement and heres the logic board: MacBook Pro 13" Unibody (Mid 2012) 2.9 GHz Logic Board
MacBook Pro 13" Unibody (Mid 2012) 2.9 GHz Logic Board Image
Product
$399.99
Score 1
Add a comment
Add your answer
Olivier L-Jacob will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 20
All Time: 425
