I have iPhone 6s not turning on
my iphone 6s is disply brokenend and i replaced its display its not turning on and when its connect to charger its heating
If you did not disconnect the battery when you replaced the screen, there is a good chance that the backlight circuit was damaged. The phone may be working but the display has no illumination. Try a bright flashlight and see if you can see anything on the display. As far as it gets hot, I've seen backlight failures cause heat issues if the coils are damaged. This may not be your problem, but it's what comes to mind as a likely cause based on your description of the issue.
I removed battery then I replaced the display. And I also try flashlight on display but it's not showing anything. If the front camera strip is broken display will shows or not
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 47
