Put charger in USB port took out TVs crackled then went off
Hi I put a charger in USB port when I went to take it out it made a crackling noise and went off it now won't switch back on any help would be appreciated it's a lg 42" smart TVs thanks
5 Comments
I'm not sure how you did this. The TV presumably has a USB A socket and a charger normally also has a USB A socket, if not a mini or micro USB plug. The only way you could connect them together is with a USB A plug to plug cable. Not something you could do by accident.
You'll need to take the back off the TV and see if you can see something showing signs of overheating or burning. If you post a photo we may be able to advise.
by Philip Le Riche
Hi yes a USB port but I was charging my ecig battery as I took the battery out of the holder that's when the noise happened I will open and have a look and upload pics thanks
by Robert
@robson12 what model is your TV?
by oldturkey03
Lg 42ln575v can't get the back off at the min have a broken arm thanks
by Robert
It's pretty much simple process! https://www.cinemaboxappdownload.co/cine...
by Gary White
