The larger version of Samsung's flagship phone, the Galaxy S8+. Released in April 2017.
49 Questions View all
Device doesn't charge after display replacement.
Hey, I needed to replace the display of an S8 Plus. Unfortunately it doesn't charge after the replacement. The temperature is too low. I tried a new battery and the phone starts but still it won't charge and I get the same error that device temperature is too low. Any ideas?
Add a comment
Chosen Solution
Hi. I had the same problem for 2 s8 and s8+. Try to assemble the whole phones, including screws, without back cover and put it in charge. It worked for me, i hope it will do it for you as well.
Score 2
Comments:
Thank you! It worked for me too!
by
Thanks was helping to save my day. you really have to assemble before charging . superb
by
Add a comment
Most Helpful Answer
Charging port is most likely faulty. I take it you used a replacement display assembly which included LCD with frame and charging port with it?
I'm not 100% sure about this but the charging port model label mismatch from the phone model can cause issues e.g SM-G920I with SM-G920F for example.
Score 2
Comments:
No I had to take the original charging port, but I will try another one and tell you if it worked! Thank you :)
by
Add a comment
Add your answer
bmgfabi will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 71
All Time: 506
