Fix Your Stuff
Right to Repair
Parts & Tools
Apple's line of iBook laptops was intended for the consumer and educational markets. The iBook line comprises of the iBook G3 Clamshell, G3 12", G3 14", G4 12", and G4 14".
1164 Questions View all
starts up but wont load OS
I have the apple on the screen, and the working indicator spinning underneath it but it is stuck in this mode. I have to unplug it, and it will be like this untillthe battery dies or is removed. I hear what sounds to be the hard drive attempting to read. Any ideas as to whats wrong?
Add a comment
Nintendo Switch Kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
1 Answer
Chosen Solution
Try booting from the install disk or into target disk mode. If you can do either (and if you can boot to the disk, then verify your driver) you can rule out bad HDD.
You should also reset your PRAM.
Add a comment
Add your answer
john p will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 595
