Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2682 Questions View all
iPhone turning off when locking phone after screen replacement
Replaced broken digitiser last night, re assembled. However the phone is now emitting a high pitched noise and then I lock the screen it shuts down the phone, only way to get phone back on is to hold lock button and home button. Can anyone help me fix this please?
Add a comment
1 Answer
Chosen Solution
First things first, try to re-install the original screen to see if the problem goes away. Depending on where you bought the replacement screen and how you paid for it, you may just have a low quality screen.
If the problem is the same with the original screen, then you may have accidentally caused damage while you did the repair. Did you disconnect the battery prior to removing the screen?
I would look through this guide and double check my steps to insure you didn't do anything incorrectly. Also take the time to visually inspect the logic board, specifically the area near the connectors to see if there is any damage to the connectors or missing or partially dislodged components. Magnification will help here.
Score 1
Add a comment
Add your answer
Maddison will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 511
