Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Data recovery , please recommend repair place
Hi. I have a problem where my iPhone 6 phone won't power up. I really just want the data. The phone does not need to work after. I sent it out for repair and it came back without the baseband ic chip. I know it's expensive but can you recommend someone to program a new baseband chip and either install it in the broken phone or in another phone and then put the logic board and other chip in to retrieve the data? Again the phone does not need to work after. I just want the data. I also have another working phone you can use to put the chips in if needed. Is that something you can do? Maybe there is another way to get the data? I would be so grateful for someone to recommend a repair place.
Add a comment
1 Answer
Chosen Solution
Reach out to @refectio or @jessabethany for this type of repair. If they can't or wont do it, they may know who will :) Best of luck! If neither replies or have any sources, you can also try Chris Long at B&C Connection LLC , https://www.youtube.com/watch?v=XjSWh14R...
Score 3
2 Comments:
Thank you so much for responding so quickly!!! I will let you know how it goes.
by
You are very welcome. If my answer helped you figure out your issue, please mark it as chosen solution to help others in the community. Thanks and Good luck! :)
by
Add a comment
Add your answer
Chloe Costello will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 120
