Diagnosing powerless MacBook Pro
Took my 2012 MacBook Pro into shop for diagnostics after small water spill. Instructed that will only turn on when power is held down for several seconds and then MagSafe charger is plugged in. After 11 days shop called. Reported they were unable to power MacBook on - apparently front desk staff didn't tell them how I've been powering it on. Diagnosed "motherboard replacement and MagSafe replacement ($875) + labor and 240GB SSD ($200). My question is is it possible to come to this conclusion and recommendation when they never even turned computer on?
7 Comments
send or take it to someone that does macbook logic board repair. most repair shops take the easier option and replace the board etc rather than fix the problem with the original board. try louis https://www.rossmanngroup.com/
by daniel
you could try yourself, disconnect the keyboard, plug in the magsafe and use the power on pads. it will tell if the power button / keyboard is bad. i repaired 1 by doing this
by daniel
Thanks. Keyboard works fine when laptop is booted up by holding down power button and then at same time connecting MagSafe power cord. Doesn't recognize battery at all (X thru battery icon) and cuts out if power cord disconnected. So would you recommend doing above anyways to rule out bad power button?
by tiffini
Daniel - shop I took it to wrote this on invoice " connected keyboard with power button to attempt to power on system' testing to check if the power button is defective (failed)."
Does that mean they already checked if it was power button and it wasn't?
And Louis said no to repairs......
by tiffini
sounds like that, if you had anyway to take the board out and take high res photos and post here someone could possibly see a problem
by daniel
Show 2 more comments
