Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
4021 Questions View all
iPhone won’t charge/communicate with computer.
Recently replaced the battery in my iPhone 6 and a new problem popped up. The iPhone will not charge through a USB port (computer or stereo) but will charge with most (but not the low amp) usb wall chargers. It will also not communicate with the computer, the computer does not see the iPhone at all.
The lightning cable is not the problem. Could the new battery be causing the communication issue?
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Chosen Solution
Most likely what you are experiencing is a Tristar (U2) IC failure. This would require Microsoldering and not a DYI type of job. If you need more information feel free to post back...but I've seen this and repaired it on countless Iphones and from what you describe, I would guess that's what is wrong. Back up your Data ASAP in case it powers off and will not power back on.
Score 2
Add a comment
The most common reason why your iPhone won’t connect to iTunes or its not communicating with your computer is that the device driver isn’t working properly; or the one of the device drivers is missing from your computer.
On a PC, the first thing you need to do is to open Device Manager. You’ll find Device Manager in Control Panel, but the easiest way to do this is to click on the search bar on your computer and type “Device Manager”.
After you open Device Manager, look for Universal Serial Bus controllers and click on the small triangle icon just to the right. A dropdown menu will open and you should see Apple Mobile Device USB Driver.
If you see Apple Mobile Device USB Driver but your iPhone won’t connect to iTunes, the driver probably needs to be updated or repaired. Right-click on Apple Mobile Device USB Driver and three options should appear: Update Driver Software…, Disable, and Uninstall.
If you see an option to Enable, click that and your problem should be solved. At some point, the driver was disabled, so enabling it again will fix the problem. if you don't see enable read below:
Uninstall And Reinstall The Driver
I have found that uninstalling and reinstalling the driver is the easiest way to solve driver issues. The driver will only appear if your iPhone is plugged into your computer, so make sure your iPhone is plugged in before you look for this driver.
Click Uninstall and Windows will remove the driver from the list of Universal Serial Bus controllers. Next, unplug your iPhone and plug it back in. When you do this, your computer will automatically recognize your iPhone and reinstall an up-to-date version of the driver.
An out-of-date driver is a very common reason why an iPhone won’t connect to iTunes, so this should fix the problem. Open iTunes and look for the iPhone icon to see if your iPhone is connected. Make sure to look at your iPhone and click “Trust” to make sure it shows up.
Important note:
It’s very important that you tap Trust on your iPhone, or it won’t communicate with your computer at all. At this point, if your iPhone is showing up in iTunes, then you’re all set! If your iPhone still doesn’t show up, keep reading.
Update (10/30/2017)
Choose The “Update Driver Software…” Option If You Can
If you choose Update Driver Software… after right-clicking on Apple Mobile Device USB Driver, you’ll see two options: Search automatically for updated driver software and Browse my computer for driver software.
Comments:
It’s not a driver issue. Other iPhones connect just fine to the computer and I’ve tried multiple computers. The problem is also present wen using the USB port on a stereo deck and well as low amp (0.5A) chargers.
by
Add a comment
Add your answer
Max Pelletier will be eternally grateful.
Past 24 Hours: 23
Past 7 Days: 161
Past 30 Days: 614
All Time: 1,165
