The Apple iPhone 5c was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 8, 16, 32 GB / White, Pink, Yellow, Blue, and Green.
1529 Questions View all
What to use instead of iPhone adhesive strips for battery?
I am replacing the battery in an iPhone 5c, but the replacement adhesive strips I had weren't good, and I don't want to leave the battery loose in the phone. So what should I use instead? I was considering using a small strip of gorilla tape.
Add a comment
Most Helpful Answer
If you don't have the original tape, I use the 3m red double sided tape 5mm as found here
https://www.amazon.com/gp/product/B00OZG...
Or any good "Thin" double sided tape that holds it firm :)
Score 1
Comments:
Would the battery being hot be a problem for the tape?
by
Negative. The batteries do not get that hot unless there is a problem with it.
by
Should I Use FlexTape™ with my iPhone Battery? Just saying.
by
Add a comment
How about using the 3M product? Stretch Release Tape 6657-150 (3M contact info)
Here's the data sheets:
I managed to get some samples to test out so far so good. I even tried some on a MacBook retina system!
Score 1
Add a comment
I messed up my white strips while fixing my battery :-( No time to order new adhesive tapes. So I double folded Scotch Blue Painters Tape #2090 so that I get adhesive surface on both sides and stuck it at the back of the battery and pressed it down. Lets see how long it works.
Score 1
Add a comment
Add your answer
Daniel G. will be eternally grateful.
Past 24 Hours: 15
Past 7 Days: 101
Past 30 Days: 398
All Time: 2,711
