7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
220 Questions View all
destoid pads for ipad mini
hey i was trying to fix the charging port port from an iPad mini 1 so i tried to desolder the charging port from the logic port and some plastic of the charging port stayed at the pads from charging port i was trying to clean it but 2 pads (the pads for data - +) broke up.. i search the pcb for ipad and i saw that they was under a tiny component that is so difficult to desolder and make jumpers... what can i do pleeasse help me
Update (10/25/2017)
those pads
1 Comment
You better take some good photos of it and post them, so we can get a better understanding of what you're talking about.
Adding images to an existing question
by
Add a comment
1 Answer
Chosen Solution
As George said, we would need a better visual of which pads were pulled to give a suggestion. Here is a pic with Ground pads in Red.
Update: Here are the 5 pads you mentioned and where the jumpers would have to run for each :)
Score 2
4 Comments:
its very difficult to solder under some components its to tiny like a pencil tip
by
Yes, I agree...it looks like a pretty difficult repair. But if you have a "Micro Pencil" iron, a scope, very small jumper wire and solder mask...It should be repairable.
by
Add a comment
Add your answer
Κωστας Λαζαριδης will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 329
