Siri will not respond to voice commands
How can I get Siri to respond to voice commands
John Sesody you did not tell us if you enabled Siri in the Settings tab. If Siri is enabled then it is possible that there is dirt etc. in your microphone or there is something blocking it. You can use a cotton swab with some isopropyl alcohol to clean it. If that still does not work try to see if Siri works with a headset. If so it is possible that your mic has failed. You will have to replace the front facing camera and sensor cable which includes that mice. Here is the guide for it iPhone 6 Front-Facing Camera and Sensor Cable Replacement
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 310
