Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
382 Questions View all
Computer won't turn on after SSD/dual HD kit install
Hey folks,
Just finished installing the iMac Intel 27" Mid 2010 Dual Hard Drive Kit with a Samsung EVO 850 250GB SSD, and upon closing things up and trying to power on the machine, I get no response at all from the computer. No fans, no noises, no nothing. Searching through forums has me believing it's a cascading issue and will probably require a logic board replacement? Power supply issue? Any thoughts? Thanks in advance!
2 Comments:
What are the diagnostic leds telling you
by
Found info on page 29 of the manual - http://tim.id.au/laptops/apple/imac/imac... - and will report back as soon as I get a chance to take a look. Thanks!
by
Add a comment
1 Answer
I had similar issues the problem was with lose connectors on the board check again and firmly tighten up the connectors to your hdd, display etc. Hope your problem resolves.
1 Comment:
Thanks! That was my first instinct and tried a couple of times without any luck. Any suggestions as to where to focus my efforts on the board - do you remember which connections came loose for you? Wondering if there was anything on the back of the logic board that might need to be addressed? Thanks again!
by
Add a comment
Add your answer
johndudleyhayes will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 83
