Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
487 Questions View all
Phone is not taking a charge
I've tried everything to charge my phone. The phone company I have won't take it for repair because I no longer have insurance on it. Should I send it somewhere else or can I fix it myself?
Add a comment
1 Answer
Chosen Solution
Here's the guide to replace your daughterboard+USB port:
Samsung Galaxy S6 Daughterboard Replacement
First try connecting it to your PC. If you can transfer data, then the port doesn't need replacement because of wear. Another test is if a Qi doesn't charge it either, then the charge circuit on the motherboard has failed, in which case you will have to replace the motherboard.
If you think it's the USB port (which is most likely), you can use a Qi charger for the rest of the life of the device, or use the guide to replace it. Parts are linked within the guides.
Hope this helps!
Samsung Galaxy S6 Motherboard Image
Guide
Samsung Galaxy S6 Motherboard Replacement
Difficulty:
Difficult
45 minutes - 3 hours
Samsung Galaxy S6 Daughterboard Image
Guide
Difficulty:
Difficult
45 minutes - 2 hours
2 Comments:
Should I replace the battery first? Does it have a battery?
by
@dmarden_345 That is a good idea. Yes, it has a battery, and this is how to do it: Samsung Galaxy S6 Battery Replacement
And this is the part: Galaxy S6 Battery
by
Add a comment
Add your answer
Debbie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 70
