Released June 2014, Identified as a Lenovo G-Series G50-45
13 Questions View all
The word 'LENOVO' has frozen on the screen.
We have tried everything to fix it:
  • removed the battery and put it back in again...nothing.
  • held down the power botton for specified time...nothing.
  • tried booting it...nothing.
  • tried Esc 6... nothing.
  • a message came up andd said the issue was with the drive or the keyboard,so inorder to find out which one was causing the problem, i had to press the tiny button on the side of the laptop...still nothing.
CAN ANYONE HELP?
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Chosen Solution
Hi!
This could be a problem with your OS. Depending on your version, I'd suggest you create a bootable drive (if you tell us the OS version I'll gladly tell you how to do that, however you will need to have access to a second PC). Pressing F2 or F12 after you insert said drive will let you choose the bootable drive. Once you get there you should be able to get to the Windows Startup Repair menu.
Score 1
Add a comment
Hi,shut down,once down hold f9 while starting,let go when your in your in your bios.not sure if its f8,f9,delete.but its one of those.once there tell it to start in safe mode.once up turn on programs that normaly start on boot,for example internet connection.do this one by one untill you find the bad one then deleate it and reinstall it.
Add a comment
Add your answer
ODEAN will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 84
All Time: 204
