Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Questions View all
Torq screw is stripped on hinge!
I tried to remove the 17" screen display so that I could repair the cracked LCD screen on my MacBook Pro 17" model A1297 and I stripped one of the torq screws. Any suggestion on how I should remove this now?
Kurt
Score -1
1 Comment
Can you post a picture so we can see how badly it's stripped?
by
Add a comment
1 Answer
Chosen Solution
Try a torx screwdriver one size smaller than the screw and use a very small piece of a rubber band. Press it in with the driver and push the driver in firmly and try to turn slowly. Here's some other suggestions: What are your tips/tricks for removing or extracting stripped screws?
How to remove a stuck screw
Then there's the Wiki on doing it: http://www.wikihow.com/Remove-a-Stripped...
Score 1
Add a comment
Add your answer
kurt6635 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,334
