Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone Replaced Battery now sleep/wake button and video mic won’t work
Recently replaced my iPhone 6 battery. Now the sleep/wake button won’t work as well as faint-scratchy/no sound recorded on videos.
2 Comments
Does you volume/mute switch work?
by
Yes it works.
by
Add a comment
1 Answer
Chosen Solution
Ok, I should've just posted my answer earlier. So you've damaged some stuff while doing your repair. The power button, which is connected to the volume/mute, which you'll have to remove the battery and the logic board. It's a pretty big repair. Youve also likely damaged the front camera flex assembly. Not that big of a job. I mean you should check that and make sure you properly seated the connections. But likely you'll have to order new a new one
iPhone 6 Power Button Cable Assembly Replacement
iPhone 6 Front-Facing Camera and Sensor Cable Replacement
iPhone 6 Front Camera and Sensor Cable
iPhone 6 Power Button Cable and Bracket
iPhone 6 Front Camera and Sensor Cable Image
Product
$19.99
iPhone 6 Power Button Cable and Bracket Image
Product
$9.99
iPhone 6 Power Button Cable Assembly Image
Guide
Difficulty:
Difficult
1 - 2 hours
iPhone 6 Front-Facing Camera and Sensor Cable Image
Guide
Difficulty:
Moderate
30 minutes - 1 hour
Score 1
Add a comment
Add your answer
eric collins will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 211
