Sony Xperia Z3 Compact released in Sep. 2014.
89 Questions View all
Xperia Z3 Compact Wi-Fi not working
Hi, I need some help with my Xperia. My WiFi has not been working for a few days, I tried booting my Phone up in safe mode but that hasn't helped.
Is this the only way to resolve it [soldering tutorial] : https://www.youtube.com/watch?v=4QzokjLJ...
Anyone have a fix?
Score 3
Comments:
Hi,
What do you mean by not working?
Can you turn WiFi on and off?
If so can you "see" networks?
Have you tried a soft reset?
Have you tried a hard reset
All the above are better options to try before opening the phone
by
Have you tried to replace battery, I had similar problem and battery was the issue.
by
Did you resolve the matter, I try to resolve the issue by changing the softwara but nothing has happened.
by
Yeah, I accepted the right solution which help me.
by
Add a comment
Chosen Solution
Your only solution is to make a soldering job, here is an example:
How to repair wi-fi wireless connection Sony Xperia Z3 Compact
Score 4
Add a comment
Before the video solution try to change software, to tell you the truth the most likely error here is connected with motherboard. The tutorial is professional job so you can use it without hessitation :)
Comments:
Software has nothing to do with it bro.
by
Add a comment
Add your answer
Ivan Wasilian will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 25
Past 30 Days: 104
All Time: 1,003
