A1418 / EMC 3069 / 2017 / 3.0 GHz quad-core i5, 3.4 GHz quad-core i5 or 3.6 GHz quad-core i7 Processor. Released June 8, 2017.
175 Questions View all
Add a SATA SSD to my iMac as a second HD (Already has blade SSD)
I didn't find any upgrade kit for 2017 iMacs. I know for 21.5 SSD-only iMacs, there should be a standard SATA connector at the back of the logic board, but what about the power? Which power cable should I use? Also where should I get the rubber bumper? Any help is appreciated!!
1 Comment
Are you sure you want to void your warranty at this time?
by
Add a comment
1 Answer
Most Helpful Answer
I agree with @mayer - I would wait until your warranty has expired. I also think you can get a better solution externally than adding in an internal 2.5" drive.
Just so you can see how much work it is review this IFIXIT guide: iMac Intel 21.5" Retina 4K Display (2017) Logic Board Replacement You'll need to get to Step61 so you can plug in the SATA & power cable on the back side of the logic board.
As far as the needed parts you can use the older 2015 SATA & power cables Apple is using the same cables here. The rubber cups are different which will be difficult to get presently.
Score 2
1 Comment:
I cannot seem to find the right cable. The only 4 pin power cable I found promising is this one "https://www.aliexpress.com/item/Brand-NE.... Can you give me a link to the right cable? Thanks!
by
Add a comment
Add your answer
Zhenfu Shi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 131
