Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1496 Questions View all
Can't pick up service signal
I can do everything else but my phone will not get any signal
Add a comment
1 Answer
Chosen Solution
Remove and clean sim
replace dock connector which contains antenna. See guide top right of this page.
Score 1
dear Pollyintop ! what up?" say ....after i recieved error -1 and water damage ,i fixed it , but now the gsm signal is constently losing,what can i do about it ? its def no sim issue ,the contacts are clean,the board is dry ,and i also have pic if you would like ,and if its ok !!!
please help bro! p.s the blue conductor coil is intact and fine!
or at least it seems to be intact ,MUCH THANKS!
@7Gnosis, pollytintop is not around as much as prior. You may want to post your question in the answer section or send an email to pollytintop. The email address is in the profile.....this all has to do with your question you left a few days ago about getting answers. It has now moved to meta:) It's tough answering questions and not getting any feedback from the person that we thought we helped....
Add a comment
Add your answer
delagarza93 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,264
