Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794 Questions View all
Crashes halfway while booting, but hard drive is okay
Hey guys,
i have a macbook pro 13' 2010. Yesterday it suddenly crashed and when i wanted to boot, there was a folder with a question mark on it.
I tried going in recovery mode but that doesn't worked. I had a Mac OS X Install DVD, so i tried that and it worked. But the installation process couldn't find my hard drive. Then i opened Disk Utility and saw my hard drive. I wanted to reset it, but that also would work. I got a “input/output” error. Partitioning also wouldn't work, i got the same error message. I googled it and they would say that the hard drive could be dead. But the SMART Status of the drive was Verified and okay.
So i decided to remove the hard drive and connect it with a other macbook. And it worked, i could reset the drive and also installed macOS High Sierra on it. I booted it with USB on the same Macbook and everything worked just fine.
Then i built it in the 'damaged' macbook and wanted to boot it. But now, halfways at the loading screen, it suddenly crashes and wants to restart the macbook. But the same thing happens again.
So the hard drive itself is working. Could it be, that the Sata cable is damaged or something even worse? Is there a way to test the cable?
Thanks for your help !!
Edit: I did a full Apple Hardware Test, it lasted 1 hour and it didn't found any problems. Really strange.
Add a comment
1 Answer
Chosen Solution
The cable (and the disk controller) are the thing in common so the evidence points to them. Except that all the bytes go through the same cable and the same controller one after another, so it's hard to see why they should only start objecting to the boot data having delivered half of it successfully!
I think you said you connected it to the other macbook by USB. Possibly the macbook USB disk driver is slightly more forgiving of disk errors than the native SATA one.
If you can connect it to a PC I'd be inclined to run Spinrite on it from grc.com. OK, it costs $89 but if it doesn't do you any good and you're convinced you won't need it again then they'll happily give you your money back. The SMART data is far from a certificate of good health, rather, it may be an indication of failing health.
But actually, a new hard disk would probably be cheaper, and you could always put it in a USB caddy and use it for backup if it was no better.
Score 2
Add a comment
Add your answer
Musa will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 264
