Help with the iPhone 5c repair
Hi, I've been attempting to repair an iPhone 5c that had been dropped. The screen was cracked, so I bought a screen and LCD with digitalizer repair set. I replaced the screen, along with the battery, and I haven't gotten anything except a black screen. No sound, lights, or anything. I can't think of what else could be wrong. I did, however, notice the ambient light sensor was damaged, but I read that it's not necessary for a phone to run. Could that be it? I've tried everything I could think of online, I've done the hold down power and home button trick, I've tested the flex cables many times, made sure they were all secure, etc. I'm hoping it's not damage to anything irreplaceable like the logic/mother boards. Any other help, ideas, or suggestions will be appreciated. Thanks.
3 Comments
does the backlight work, you should see this if the screen is lifted up, also it could be possible damage to the logic board as it was dropped
by daniel
No, the screen does not light up at all. I'm beginning to fear logic board damage.
by Josh Andrews
@jifpeanuts double check the battery work. Make sure that there are no components that are missing near the battery connector etc.
by oldturkey03
