Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Full memory, won't turn on after soft reset
So, I got an iPhone 6 today, running very oddly. I soft reset it and now it will not boot all the way. Stays on the apple logo for a while, then shuts off all of a sudden.
No internal damage, new lightning cable didn't help.
Owner then mentioned that it was about 100% full with data/apps and photos.
Any way to restore the iPhone with data intact? Or to backup the data before restoring? I'm downloading the correct ecto ios versions now to give it a go.
Score 3
Add a comment
Chosen Solution
Yeah..I mean if you can connect it to iTunes? Then you can back it up. Save the data, do a restore to the backup. With that being said, when you back it up, it'll have all the contacts and pictures and what not. But it won't have the non essential apps. So the phone will work. But the customer is going to download more things, and this will happen again. They really should get a new phone with more memory, to be able to handle all the data they're using
Score 1
14 Comments:
I can only connect it to iTunes in recovery mode though as it will not boot up all the way
by
Ruh roh. That means corrupted data, and you'll have to do a restore. And whatever hasn't been saved is lost. I've been promoting awareness with my customers to just pay the 99 cents a month for iCloud storage. It saves in times like this
by
Alright, thanks for the heads up. Bummer to hear! Any recommendations for a program to potentially get any of that data back? Or is the encryption going to kill that possiblity?
by
Have you ever tried 3utools.com? It's possible you could soft boot it. But you'll need to know which version of iOS you have
by
I just got 3utools today. Upgrading to ISO 11.0.3 seemed to clear things up. The clients whatsapp disappeared though. Kinda odd. A few gigs free now. I grabbed a backup and will have them delete about 1k of photos or just iCloud them.
by
Show 9 more comments
Add a comment
Reiboot software alow to leave stuck boot without restore iOS, you should try it
Add a comment
Joseph Hughes:
Were you getting an itunes (9) error when you tried to boot up thru itunes?
My iphone 6s, got completely full, and I am getting iTunes error(9), on attempt to update ios thru itunes.
so far people have said error(9) has poor data recovery rate, so they were hesitant to troubleshoot my phone.
Thank you.
1 Comment:
Error 9 is generally an issue with the NAND, like a bad power line or something. It could potentially be a bad NAND itself (NAND is the memory chip, basically the hard drive for your iPhone)
I would ask a local technician that is competent in micro-soldering and iphones on a component level to verify all NAND power lines are good to go, no missing voltages or such, before calling it quits :( There is a pretty high possibility that the NAND its self is the problem meaning no data recovery is available.
by
Add a comment
Add your answer
Joseph Hughes will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 29,190
