Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
844 Questions View all
Stuck at Apple logo at boot up iPhone 7 plus
Hi all!
we have another problem facing us: iphone 7/7+ - if you are so unlucky to break your homebutton or sensor flex, your phone will not boot, it will just stay at the apple logo. You simply cannot just go changing them with aftermarket parts or OEM parts, it must be fully original (not chinese-original), which means 1. much, much harder to get, 2. much, much more expensive. This does, however, not effect screens, you can easily use the high copy grade - as long as the small parts are ORIGINAL! So, fair warning my friends, be very careful not to bust anything when taking the screens apart. Basically, Apple reinstated error code 53, but not as an itunes error, more as a phone that'll brick when booting. If you switch to original parts, it boots just fine again. Apple has not yet solved this in the latest update like they did touch-ic error on iphone 6S, and who knows if they will at all. Back in the day, they got convicted into removing error 53 (if you had aftermarket homebutton installed on ip6, your phone would brick on updating in itunes, until original button was mounted), as it was a violation of consumer rights, as Apple was making it possible, only for Apple to fix it. We are facing the same problem here, basically - and as i see it, there are 2 solutions: Apple will have to change this (as this haven't been a problem the since ip7/7+ release, but is a new thing in thread with ios 11), or we be very careful, and buy original parts when we mess up. My personal opinion: get a lawsuit going, so we get the possibility and freedom of using the parts we want (and the customers want in most cases, as it is much cheaper for them as well), back!
BTW, i don't know if this can be viewed as a question, sorry for that! This is basically just knowledge i've been researching, and passing on to you, so that you don't have to spend days looking for a fix that will not work ;)
Add a comment
Chosen Solution
You might want to make this an answer on this question (iPhone 7 home button not working after screen replacement), which is currently the definitive thread on iPhone 7 Home Buttons.
Score 2
Comments:
Perhaps yeah, but the issue that he has there is either: a. he broke the button physically while taking it apart, or the flex that run in the screen is bad - has nothing to do with boot fail :)
by
The homebutton is fine - work with 10.3.3. When I replaced my screen i ripped the front camera flex, thats all. Spoken with Apple and they did a diagnostic and found that the ambient sensor was failing, so i bought a aftermarked front camera flex. Everything work fine with 10.3.3 but im to afraid to update to 11.0.3 because of this.
by
I think it depends on the quality of the aftermarket flex, if you paid enough for it, chances are that it's original - but i can't tell you..;) However, it is a possibility that they will correct this, as it's in IOS 11 the issue is on.. I'd wait a week or 2 before updating, you can always see what improvements come with the next update, you know, like they changed the whole touch issue in 11.0.3 - give it time, and pay attention to the updates as they come, i think it'll solve itself.. :)
by
Add a comment
Restored the phone and everything is like new again. Had an issue during the restore with the i7. It wouldn't stay in DFU mode. Kept kicking back on and to the Apple logo. Went to this link (iPhone won't stay in dfu mode long enough to restore?) and was able to download the direct firmware link. Follow those instructions and good as gold.
Add a comment
I have same problem with broken flex cable ftom button, the iphone succes boot to OS but like 30minutes.... check another screen also.... sometimes original button+original working screen= not working homebutton i dont know why....
Add a comment
Add your answer
Mikkel Øgendahl will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 60
All Time: 6,028
