Model A1288 / 8, 16, or 32 GB capacity
451 Questions View all
Question Closed
Location Services "cannot determine location!" why?
Location Services "can determine location !" via wi-fi around public areas
but it "cannot determine location !" via my vista operating laptop with cellular 3g internet and microsoft security essentials installed.
Location Services are already enabled. But don't work.
can anyone help?
Add a comment
Most Helpful Answer
Try this article and see if that will help you? Seems to be a setup issue, probably related to your Vista laptop setup. http://www.technipages.com/ipod-touch-ho... Good Luck
Score 3
6 Comments:
thanks but it doesn't work
by
have you tried this http://cydia.pushfix.info/ or have you tried a Network Reset (in Settings)?
by
This didn't work too. I think there is a problem with the "microsoft security essentials" installed. I need help again.
by
Did you get your email back from skyhook? If so, turn off your firewall. The firewall is more than likely blocking the skyhook service.
by
I sent my location degrees and even pointed on the map but skyhook didn't email back after examining
by
Show 1 more comment
Add a comment
Try getting into the configuration settings for the Microsoft Security Essentials. There may be some sort of setting which might be causing the problem. The Location Services on the iPod Touch as you know, only works when the Wi-Fi is on, and I suspect the Microsoft security program might be preventing the location service from working. If this is the case, I suggest you uninstall the program and try again.
4 Comments:
sorry Jon. This doesn't work too.
by
Try going to a place that offers free Wi-Fi service; Starbucks is
one such example and try it there. If it works, then it might be some sort of security setting.
by
hi Jon it works with wi-fi services around but it doesnt work with my laptop with microsoft security essentials installed.
by
Try looking at your security settings. There may be some sort of setting that may be blocking the location service on your iPod. Otherwise, try uninstalling the program on your computer and try again.
by
Add a comment
Add a comment
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 7,258
