Model A1418 / Mid 2014 / 1.4, 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
30 Questions View all
añadir SSD a placa que viene sin conector / Adding SSD connector & SSD
Hi,
The motherboard of my system did not come with the SSD connector, it is possible to solder the connector and add SSD?
Will it would work
Comments:
hello, you sure are not worth adding the connector
by
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
1 Answer
Chosen Solution
Spanish: Tristemente Apple no pobló la placa lógica en algunos modelos con todas las partes. Hay más componentes que el conector, hay otros componentes necesarios para agregar en el conector de la cuchilla SSD PCIe.
Si está buscando actualizar su sistema a un SSD, puede ir con un SSD de 2.5 "que reemplace su HD. Esta es la guía de IFIXIT que debe seguir: iMac Intel 21.5" EMC 2805 Hard Drive Replacement
English: Sadly, Apple didn't populate the logic board in some models with all of the parts. Theres more than the connector there are other components needed to add in the PCIe SSD blade connector.
If you are looking to upgrade your system to an SSD you can just go with a 2.5" SSD replacing your HD. Here's the IFIXIT guide you'll need to follow: iMac Intel 21.5" EMC 2805 Hard Drive Replacement
Add a comment
Add your answer
Juan Manuel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 37
