Waterproof action camera (model no. CHDHS-101) released by GoPro in July 2015. The Hero4 Session shoots 1080p video and 8MP stills.
24 Questions View all
Looking for the internal lens assembly. I have it completely apart.
I smashed the internal lens of my go pro session 4. I have taken it apart and don't know where to purchase the lens assembly. I figured the lens assembly and sensor will need to be purchased together because the lens is glued into the assembly probably for focusing. I was able to get it screwed out but figure there will be no way to refocus it with a new replacement....
Score 2
Add a comment
1 Answer
Most Helpful Answer
I was wondering also if one of the two will work since the sensor size is supposed to be the same:
GoPro Hero Lens
[linked product missing or disabled: IF300-109]
I am about to receive a cracked lens Hero Session and will followup with what I find.
You should be able to refocus by using a calibration target to make sure image lens is screwed to correct position for proper focus, then maybe hot glue in place:
http://www.vision-doctor.com/en/line-sca...
GoPro Hero Lens Image
Product
GoPro Hero Lens
Score 1
2 Comments:
So, were you able to replace the lens?
by
Yes, in regards to the outer lens. No, wasn't required regarding the inner from what inspection I've performed so far.
I found the outer lens destroyed and the inner lens wasn't in as bad of shape as the listing noted. I replaced the outer lens, invested in a aluminum 52mm lens adapter, a 52mm CPL and lens cover also. I haven't performed a thorough image analysis though.
Thankfully, from what I can tell that appears to be imperfect on the internal lens from a visual inspection... isn't observable in the images from a quick review.
by
Add a comment
Add your answer
Josh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 593
