Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
309 Questions View all
MacBook Pro A1286 isn't turning on at all
My MacBook Pro 15" A1286 won't turn on at all. Battery is fully charged.
The last 3 digits of my S/N: 64C
I opened the back cover removed and reinserted most cables... but nada
Can some one help?
Comments:
Sadly we can't ID systems with just the last three digits of the S/N any more ;-{
The A1286 series is quite large can you pick it out from this list? A1286 models or if you plug in the full S/N here: EveryMac - Lookup. Then post the systems URL for us to see that would help us help you.
by
Thanks Dan,
Here's the URL of my MacBook Pro Specs:
https://everymac.com/systems/apple/macbo...
by
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
OK lets see if we can start the system using the power pads. Carefully jump across pin five and the ground post it only takes a moment (don't short out any of the other pins) Here's a image to help you:
Are you able to start the system this way?
Score 2
Comments:
Question: keep it jumped while pressing power? or jump it for how long (secs)?
Also keyboard ribbon seems disconnected in the picture you posted. Procedure would be helpful.
by
Could you describe this process a bit more in depth, or link me to somewhere that does? I'm unfamiliar with this kind of resolution.
by
@jac1 - Count off; One, Two & Three... ;-} All it takes is a moment.
by
@iwaffle - Alek all were doing here is to isolate out if the upper case is the cause of the problem or if there is something deeper. This just a diagnostic step, we haven't fixed anything yet.
by
I see, thank you for the clarification.
by
Show 8 more comments
Add a comment
Add your answer
JAC will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 67
All Time: 695
