Indecators blinking and operation hanging, no water coming in.
Electrolux care plus esf 6549, indecators blinking and operation hanging, no water coming in. It will keep this over and over. If I fill some ater inside, then t will drain and pump some water inside, but at the same time it will vacume the water out and led diods on 65 c and water in indecators start blinkin! It seems like something hanging. I clean the waterin filter on the house, and testet that the water precure ok. I also put calcuim remover and wait 2 days, but nothing happens more.
Anybody can help with this?
Comments:
The failure cause was the solenoid water valve.
by
Add a comment
1 Answer
MKA this could be an issue with the door latch/switch. Use your multimeter and check the latch for continuity and let us know what you get.
Comments:
Ok thnk you, I will check that tomorrow and tell you what will happen.
by
Hi, it is the solenoid water valve doesnt react. I ordered replaceent. So the failure has nothing to do with the latch. Thank you.
by
Add a comment
Add your answer
MKA will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 58
