The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3363 Questions View all
Can you use denatured 70% alcohol an iPhone motherboard?
Having problems with the digitizer connector on my friends iPhone 5s.
Thanks in advance for your answers.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Hi Julian,
You can but it is highly suggested that you go with the higher 90% which an be found at most pharmacies.
Score 2
Comments:
@appelboom @blakeklein is absolutely right. Remember that it contains
63.4% Ethyl Alcohol
3.2% Methyl Alcohol
3.4% Isopropyl Alcohol
and 30% Water
Not a great mix for proper cleaning. Stick with a high percentage (90%+) isopropyl alcohol.
by
Okay, I'll try that then. Thanks a lot guys!
by
Add a comment
Add your answer
Julian Riemersma will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 35
