Repair guides and support for cars and trucks by Dodge.
754 Questions View all
What's the best way to install cooling fans
What's the best way to install cooling fans on a 1998 dodge stratus?
1 Comment
@buckhunter53 are you inquiring about replacing the stock fans?
by
Add a comment
1 Answer
Chosen Solution
@buckhunter53 here is how they get installed. So in your case you will have to start at the end of this:
Replacement
  • Disconnect the negative battery cable from the ground stud on the left shock tower. Disconnect the fan motor electrical connector
  • Remove the upper radiator crossmember, either detaching the four bolts and laying it aside, or also removing the two bolts to the latch and removing the crossmember entirely.
  • Remove the fan shroud mounting bolts, detach the clips at the top and bottom of the shroud with a small screwdriver, detach the wire harness clips from the shroud, then carefully lift the fan assembly out of the engine compartment.
  • Note: It is easier to remove the fan assembly if the upper radiator hose is disconnected first from the radiator.
  • To detach the fan blade from the motor, remove the nut or retaining clip from the motor shaft. Remove the fan blade from the motor.
  • To detach the motor from the shroud, remove the retaining nuts or screws. Remove the motor from the shroud.
  • Installation is the reverse of removal.
Note: When reinstalling the fan assembly, make sure the rubber air shields around the assembly are still in place - without them, the cooling system may not work efficiently.
Score 1
3 Comments:
Thanks oldturkey03!! I was just curious if it was easier to disassemble with the radiator attached as one unit because of the lack of room? I really appreciate your input on this!
by
@buckhunter53 either way it looks to be a pita. I think for as long as you have the upper radiator hose removed, you should have enough room to shimmy by.
by
I have another issue with this car , although it's related. It has bad cooling temp sensor and it was preventing the fans from coming on and the motor overhead and shut off. Now I unhooked it now the motor is running rough. Can it be because that sensor is not hooked up or is it another major issue? I really appreciate your input on this!! Thanks!
by
Add a comment
Add your answer
John Walker will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 47
