Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
My iPhone 6 didn't work but now it is, what's up with it?
I opened up the snapchat app and all of a sudden there were white and green lines going up and down the screen, it then shut off. I tried holding the lock button and home button together and even plugged it into the charger but it wouldn't turn back on. About 2 hours later, I decided to try again and it turned on. It is perfectly fine without any lines.
What is wrong with my phone?
Add a comment
1 Answer
Chosen Solution
Hi Cara, it's hard to fix something that un-breaks itself ;>).
It is possible that it is application related. I would continue to monitor the phone and see if this happens again and under what circumstance. If it happens again under Snapchat, then I would delete the app and install it fresh to see it that makes the problem go away. If it happens again under a different app or circumstance, then I would start to suspect a bad screen. You can find a replacement guide here if you are interested in changing it yourself.
Score 1
Add a comment
Add your answer
Cara Kim will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 31
