The HTC Vive is HTC's first virtual reality headset, co-developed with Valve released in April 2016. The device's model number is NM80PJT100.
11 Questions View all
The power button is loose and won’t turn the Vive on.
The power button on the Vive presses with no resistance, and it doesn’t turn the device on. All the cables are plugged in. What could be the problem?
Score 1
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
If there is no feedback from the power button, then the outer shell has probably been knocked out of place. The button is attached to the shell and is supposed to be over the power switch, but the button can fall out of place. You can follow the steps in the HTC Vive Outer Sheath Replacement to set the outer shell in the correct place again.
Add a comment
Add your answer
Gabe Musen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 82
