The Nokia 6086 is a well-built, basic camera phone with the ability to make calls via Wi-Fi.
1 Questions View all
6086 won't turn on completely when text memory is full.
(Possibly in combo with when battery dies)..unless sim card removed. W/ sim card in, it will get past Nokia screen to white screen with time and battery indicator..eventually goes black & shuts off. (As the memory is filling up, it took longer & longer to turn on, til it couldn't turn on at all.) With sim card out, it turns on and gets menu, but says 'memory not ready' for all text menu (so can't clear memory), and gets stuck on a waiting screen for galley & apps. Basic reset doesn't help, restore settings code (*#7370#--takes forever to look like it's doing something) doesn't help either...same wallpaper. Returned 3 times under warranty...1st they did factory reset, then software upgrade, then replaced the phone. Now the new phone is doing it too, but no longer under warranty. Can I do a factory reset on my own? (My carrier doesn't allow software upgrades...if I can even do one w/out the sim.)
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
MPS here are the codes that I collected for the Nokia phone? Why would your carrier not allow you to update? Anyhow looks like you might just have to contact your carrier to see if it is a sim card issue.
Basic Reset or Soft Reset for nokia 6086
This option restores the .ini files from the ROM.
Does not erase data (photos, videos, documents) or applications from
a third party. Key Code *# 7780 # (click this combination of keys on the
keyboard in the mobile)
Total Reset or Hard Reset for nokia 6086
This option restores the original operating system from the ROM.
Formats the C: partition and deletes all data including the memory
card. Key Code *#7370# (click this combination of keys on the keyboard
in the mobile)
Important: To proceed to reset, the battery must be full and the
mobile device connected to the charger. If during the course of reset,
the mobile stop receiving electricity it can ruin the internal flash
memory of the mobile device and stop function.
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
*#62209526# - Display the MAC address of the WLAN adapter. This is available only in the newer devices that supports WLAN like N80
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
*#7328748263373738# resets security code.
Default security code is 12345
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin#
http://www.ehow.com/list_7710907_nokia-6...
Any chance that you could connect it to your PC and clear the memory with the Nokia software?
http://www.howardforums.com/showthread.p...
hope that this helps you out a little bit but at this time it looks like you do not have much of a choice.
Score 2
Add a comment
Add your answer
MPS will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 990
