Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
828 Questions View all
How do you repair torn ground foil on the logic board?
Just received the new logic board for my 5.5 and was able to take everything apart following the how-to document. My only issue was that the Foil removal from the old bard and re-install on the new board was not discussed...or I missed it. Of course I was not careful enough and the the thin lead that goes to the case for ground has torn.
How do I fix it?
As a dosumentation suggestion:
Looks like either here:
iPod 5th Generation (Video) Logic Board Replacement
or at Step 19 (Or new Step 20), we need to instruct on how to remove said foil.
I found that after mistakenly pulling the ground tab piece (which casued the foil break) that peeling up on the round (white underlayment) from the base-end of the logic board is the best method as it does not put stress on the foil itself.
Add a comment
Chosen Solution
mbivona, I actually used my old foil as a pattern and got some aluminium foil from the local grocery store and cut it to fit and used some glue, not crazy glue but a non running fabric glue, and put it in place. Worked well for me. Good luck
Score 2
Add a comment
I don't think you even need to ground that. It can work without ground.
Add a comment
Add your answer
mbivona will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,039
