Apple's 2016 revision to their laptop lineup targeted at professional users. Features a 15-inch, 2880-by-1800 Retina display, quad-core Intel Core i7, 256 GB / 512 GB /1 TB / 2TB storage options, 16 GB RAM, and a keyboard equipped with a Touch Bar. Released November 2016. Features Model A1707.
260 Questions View all
MacBook 2016 touchbar after only 1 week use won’t turn on
I just broke my MacBook Pro!
I had fully charged it, then travel with plane when I arrived, it didn’t work. I tried resetting SMC, I tried holding the power button in different scenario, I even opened her up disconnected the battery and no luck, I was wondering where are the power pads to jump start the mac?
And what do you guys think happened ?
I did set an appointment but it’s in 10 days and I really need my computer!
Thanks
Score 1
1 Comment:
Bummer, Sorry to hear about your computer. Did you spill anything on it during the plane ride?
by
Add a comment
Unfortunately, the 2016 and 2017 MacBook Pros no longer have power on pads.
Update (10/06/2017)
I would try booting it in minimum configuration. Disconnect everything from the logic board, and then plug it into power. The 2016 and 2017s now auto boot when plugged into power. If it is booting in minimum configuration, then you can add components to see what is causing the problem. If it still does not boot the logic board will need replaced.
1 Comment:
whether the fan is removed too
by
Add a comment
i see, any suggestion ? i had this problem with macbook 2011-2013 and when i disconnected battery and reconnected it it was fixed but in this one nothing helps
1 Comment:
See revision to my previous comment.
by
Add a comment
Add your answer
mehrad raissi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,088
