Will not drain. Press drain but don't hear anything happening.
Pressing drain on dishwasher and nothing is happening I hear no noise as if motor was actually running/pumping water out. Pipes are clear, disposal clear. Drain pump maybe? mod# WDF310PAAS4 dishwasher runs fine but will leave water after full cycle
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Cause 1
Drain Pump
The drain pump uses an impeller to force water through the drain hose. If the drain pump motor is not working, the dishwasher won’t drain. To determine if the drain pump is defective, check the pump motor for continuity using a multimeter. If the motor does not have continuity, or if is getting power but won’t run, replace the drain pump. Drain pumps are not repairable—if the drain pump is defective, you must replace it.
Cause 2
Drain Impeller
The drain impeller pushes water through the drain hose and into the garbage disposer or drain line. If the impeller is broken, replace it.
Cause 3
Drain Solenoid Kit
The drain solenoid opens the drain valve to allow the water to exit the dishwasher. If the drain solenoid fails the valve will not open causing the dishwasher not to drain.
Score 2
Comments:
Awesome, thanks, I appreciate it a lot.
by
Add a comment
Add your answer
Aaron Bethell will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 21
