4-inch iPhone released in March 2016 with similar hardware specifications to the 6s. Available in Silver, Space Grey, Gold, or Rose Gold with 16/64 GB storage options. Model A1662 and A1723.
465 Questions View all
Battery drains fast and when totally flat it won't even charge.
For the start, my battery does not last more than 5-6 hours. And when it drains completely it does not react to the charger anymore and stays totally flat, like the electricity is not even coming into the phone. I replaced 3 batteries already. I suspect the U2 IC chip as I used to use cheap usb chargers before.
Any clue what this could be and who can repair this for me?
Add a comment
GIVE TOOLS. FIX FOREVER.
GIVE TOOLS.
FIX FOREVER.
Spread the Fixmas cheer.
1 Answer
Chosen Solution
If you have already tried 3 replacement batteries, then yes, you most likely have an issue with the charge circuit on your phone. Cheap USB chargers can do that.
This requires a micro-soldering repair. You can search Google to see if anyone locally does it. Just search "YOUR TOWN MICRO-SOLDERING", it should find someone. Barring that, then you can also widen your search as most micro-solderers accept mail-in repairs. There are a few reputable micro-solderers who patrol this forum. You can check out my profile if you'd like, at the very least it will serve as a data point.
Score 2
Add a comment
Add your answer
DELETED will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 41
