4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Questions View all
Battery drains fast and when totally flat it won't even charge.
For the start, my battery does not last more than 5-6 hours. And when it drains completely it does not react to the charger anymore and stays totally flat, like the electricity is not even coming into the phone. I replaced 3 batteries already. I suspect the U2 IC chip as I used to use cheap usb chargers before.
Any clue what this could be and who can repair this for me?
Add a comment
1 Answer
Chosen Solution
If you have already tried 3 replacement batteries, then yes, you most likely have an issue with the charge circuit on your phone. Cheap USB chargers can do that.
This requires a micro-soldering repair. You can search Google to see if anyone locally does it. Just search "YOUR TOWN MICRO-SOLDERING", it should find someone. Barring that, then you can also widen your search as most micro-solderers accept mail-in repairs. There are a few reputable micro-solderers who patrol this forum. You can check out my profile if you'd like, at the very least it will serve as a data point.
Score 2
Add a comment
Add your answer
DELETED will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 58
