Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1392 Questions View all
Exchanging harddrive between two MB Core2 Duo fails
I have 2 A1181. I wanted to easily switch all data from one to the other by just exchanging the hd. The one hd had 3 or 4 (dont remember) extra pins on a socket on one side. On the other hd there wasnt a socket connected to the board on that place. When i installed the hd the macbook started again and again without coming to the apple logo.
SMC-Reset didnt work.
Any suggestions?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
The extra pins are most likely ID jumpers or designate SATA II. They should not have any jumpers on them. I'd put them back the way they worked and do this in "Target Mode". Connect the two units via a firewire cable and start one up holding down the "T" key. This will bring its hard drive icon up on the desktop of the other machine. Then just drag and drop what you want to move.
Add a comment
Add your answer
Nathan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 550
