lines coming down the Tv screen
My aoustic solutions 32" LCD TV has lines coming down my tv every time it turns on it disappears after 20 mins but really annoying i have taken it to a TV shop they don't have a clue they have tryed my tcon board ribbons the lot what can I do?
Add a comment
1 Answer
Chosen Solution
@jeh83 if those lines disappear after warming up, it sounds like a cold solder joint. Could be on any boards, but most likely the T-con board. You could try and replace it or use some freeze spray. Remove the back of your TV (do not touch anything) . Then turn the TV on and once it warms up so that the lines disappear, spray some freeze spray on the board, cover a few components at a time. Once you get the lines back you will discover which component is giving you problems. Post some good images of those boards with your question. that will allow us to see what you see. Use this guide Adding images to an existing question for that.
Score 2
Add a comment
Add your answer
josh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 103
