Fills with water but won't cycle. Have cycled power without any differ
Doesn't cycle. Fills with water and drains. Have already cycled power at breaker but no difference
Comments:
@sooner what model is your dishwasher
by
Whirlpool bought about 1 yr ago.
by
Model W10632077A
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Cause 1
Thermal Fuse
The thermal fuse shuts off power to the dishwasher if it overheats. If the thermal fuse blows, it will prevent the dishwasher from starting. To determine if the thermal fuse is defective, use a multimeter to test the fuse for continuity. If the thermal fuse does not have continuity, replace it.
Cause 2
Door Switch
The door switch prevents the dishwasher from running while the door is open. If the door switch is defective, the switch will prevent the dishwasher from running even when the door is closed. To determine if the door switch is at fault, use a multimeter to test the switch for continuity. If the switch does not have continuity, replace it.
Cause 3
Door Latch
The door latch ensures that the dishwasher door latches shut. If the door does not latch properly, the door switch might prevent the dishwasher from running. If the door latch is broken, replace it.
Score 2
Add a comment
Add your answer
Rick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 30
