The iMac is Apple's line of all-in-one desktop computers.
5971 Questions View all
Where online can I download OS X 10.11 El Capitan?
leave link in the comment
Score 7
Comments:
im trying to download oxel captain
by
Read my post from 9/26/2017 on this page.
by
I had a ѕіmіlаr іѕѕuе, Appstore only has OS El Captain updates and not the original OS.
Fіnаllу I managed tо get OS X El Capitan
Fоllоw this guіdе hеrе: http://bit.ly/OSElcapitan
Hope this helps
by
Add a comment
Hey, you can download it from the Appstore.
Or
Check here: https://support.apple.com/en-us/HT206886
Alternative link: https://7labs.heypub.com/tips-tricks/el-...
Direct pkg link: http://osxapps.itunes.apple.com/apple-as...
Score 3
Comments:
I tries the Direct pkg link, downloaded fine but wont work/open to view files... Can someone help please ! Thanks
by
any luck opening file?
by
Add a comment
@realadain El Capitan is not available to download via the Mac appstore. IF you didn't downloaded it while it was the latest OS X, you cannot download it legitimately. If you did get it originally, it would be in the Mac App store under the "Purchases" section where you can re-download it. The current OS X is "High Sierra".
Don't download 3rd party programs to create bootable USB.
There is in fact a way to do it natively.
See the section on this link using the "createinstallmedia" terminal command (section 2).
http://osxdaily.com/2015/09/30/create-os...
Score 2
Comments:
thank you mate i will give it a try
by
Add a comment
Hi @realadain, I would recommend you to use DiscMaker X! to create a usb bootable,
find a mac and install the application, follow the instruction on the screen to create the usb installer.
Score 1
Comments:
okay thank let me try this
by
Add a comment
I don't know what year iMac you have, but you can start up from the repair partition or a blank formatted drive and do an internet installation. This procedure will install the original operating system to the machine. Any system prior to the original will not work on your machine.
To use Recovery Mode, follow these instructions:
Shut down your Mac.
Press the Power button
Immediately press the command (cloverleaf) key and R together.
Make sure you're connected to the internet through Wi-Fi. ...
Select Install Mac OS X, then click Continue.
Wait.
Score 1
Add a comment
you will find all MAC OS here
https://support.apple.com/downloads/maco...
Comments:
only OS updater files, individual or combo are available via that link...not the original full install of the OS...can't even get current 10.13 High Sierra from that link
by
Add a comment
Add your answer
Adain will be eternally grateful.
Past 24 Hours: 370
Past 7 Days: 2,570
Past 30 Days: 10,886
All Time: 41,731
