Apple Watch Series 2, announced September 7th, 2016 and released September 16 2016.
132 Questions View all
Would replacing my screen jeopardise the watch’s waterproof properties
I have a large, deep scratch in the screen of my Apple Watch series 2. It has started to get on my nerves, and I have begun to consider replacing the screen myself. Would replacing the screen cause the watch to no longer be waterproof?
Add a comment
Chosen Solution
First it is water resistant not waterproof
https://support.apple.com/en-us/HT205000
If you do the repair, any remaining warranty you have will be kaput.
Replacing it yourself and getting as good a seal as the factory did is unlikely.
The part is out of stock and expensive. I'd call Apple as see what they are charging first.
Score 2
Add a comment
There's no way to guarantee that it would still have the same water resistant rating. Also, the replacement adhesive strips I have found so far are a bit thicker than the OEM one. So after you re-set the screen in place, it sticks up a teeny, tiny bit higher than it did originally. Literally, we're talking a fraction of a millimeter, but it is enough to feel. And if you really look closely, you can see the difference too. Does that matter? Maybe, maybe not, but personally, I worry a little bit about the edges of the screens being that much easier to chip.
Personally, before I did anything else, I would try picking up a good screen protector (probably one of the plastic ones like the stuff from Armorsuit, not a tempered glass one) and see if that covers up the scratch enough to not bother you so much.
Score 2
Add a comment
Add your answer
Luke Rogers will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,204
