The AUX doesn't work, the Jack Socket was broken
I have a Bose bluetooth speaker II, the hole of AUX was broken, how can I fix it.
Thank you very much!
@chunxia this sounds like the AUX has come off and been pushed in. this guidewill get you to the boards. then take a couple of good pictures and post those with your question. It will allow us to see what you see. Use this guide Adding images to an existing question for that. Most likely soldering a new connector to it should resolve the problem.
Guide
Difficulty:
Very easy
2 - 5 minutes
Guide
Difficulty:
Difficult
6 minutes
Hi, I have the same problem: is the AUX port definitely soldered on, or is there a way to fix this issue without soldering? Thanks, Lucas
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 957
