Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone 6 won't turn on and repeatedly restarts on iTunes
Hello,
iPhone 6 won't turn on and when plugged to PC via USB it keeps restarting so fast that my PC just beeps like everytime I plug/unplug USB.
iPhone doesn't give any signs on screen, just dead. On iTunes first message I can see is that is in recovery mode.
I tried with different cable, tried to clean ports, still nothing.
Like its something faulty with charging port itself(ie. bad connection?)
Any help would be appreciated!
1 Comment:
Have you tried a hard reset on the phone? Hold in the home and power buttons. This tends to fix a number of iPhone issues.
by
Add a comment
1 Answer
i would start doing a hard reset.
if that did didly squat, try placing it into DFU mode and restoring on itunes.
2 Comments:
It won't work. PC just beeps like its connecting/reconnecting.
by
if you know how to open your iphone, disconnet battery for ten seconds, then reconnect. its the best way of sure fire power cycling. at the end, it should be able to go into DFU mode. if not, then i suggest going to your nearest genius bar.
by
Add a comment
Add your answer
Vuk will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 39
