I have a lot of colored lines running down my screen, can it be fixed
I have a lot of colored lines running down and across my screen, what is this indicative of and can it be fixed?
Sanyo LED 42" Flat Screen
Eula Gardner you are not giving us much to work with here. Vertical Lines could be indicative of a bad panel, bad t-con board, bad cables or bad main board. Now if you tell us what model your TV is and post some images of what your screen shows, we probably can narrow it down a bit. Use this guide to post some images so we can see what you see. Adding images to an existing question
Thank you for adding the image. This is a broken LCD panel.
You can try and find one by using the number of the back label on the panel. It may be difficult to find those since they are costly if they are even available. You can try and purchase the same make and model TV as yours but that is broken other than the panel. then harvest the panel from that.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 427
