no logo but backlight is on
i have this lg tv with this problem
i start the tv the red led is flashing 3 times and the back light comes on but the lg logo do not .so no picture comes on.i replaced the main board because the tcon is on the main board but it did not help i get the same problem.i checked all the voltages and they are ok.
cant figure what is the problem?
5 Comments
@shopy what is the exact model number of your TV? you replaced teh Main board or the power supply? LG has issues with the caps on the power supply.....What voltages did you check?
by oldturkey03
well i continue checking and i found somthing disturbing
when i disconnect the lvds cable in one side of the lcd i get the logo one half side of the screen and plain white on the other half screen.i checked the lvds cables by sweeping them and i got the same result.but when i connect this side that is white back i do not get any logo on screen.
so i assume the problem is the lcd screen that prevent the tcon board to operate maybe it is a short in the lcd or something else.
i cant figure if it is possible that the lcd screen can do this problem?
any suggestion??
by david shapira
@shopy that does not sound like any LCD error at all. If anything I would say it is a T-con issue,
by oldturkey03
I replace the tcon with a new one .so it cant be the tcon.
by david shapira
One side of the LCD panel is defective
by Jax
