My Screen Shows Horizontal Lines, and Screen Flicks & Flashes
Hi,
I am using an android device, Micromax Canvas Nitro A311, I have a problem with my screen with horizontal lines across its screen.
3 month ago it was felt from the height you can measure from at a human palm to the human elbow, still it did not affect. Then sometimes in travelling it got some slight pat and knocks, even it don't affect it.
A month ago it was wet inside a pool of water but after drying it started working, with no error (no graphic/display problem started yet).
3 days ago, it flashed horizontal lines at the bottom of the screen upto the lower of the middle of the screen. It flashed with light, I thought that might be the cause of overheating of the device, so I used clean master app to cool it down. Fortunately, the lines dimmed down and it disappeared after 5 minute, and since then my graphic was healthy like as before this problem.
But, today, on 22 September 2017, at the time of 11:49am (+05.30 IST), it again showing the same lines across the lower middle of the screen.
Please help
Score 2
1 Comment:
The same horizontal line problem started today morning onwards. Not in regular basis but occasionally. But for my case it never fallen and same model Micromax nitro a311 model. The broken line sometimes fluctuate and later automatically stops also. It happens quite sometimes. Is there any problem regarding software update or virus or anything else.
by
Add a comment
1 Answer
@msqrockstar92 this could be a broken LCD ,post some pictures of what your LCD shows with your question. Use this guide Adding images to an existing question for that. It is also possible that the water damage has corroded parts of your logic boards circuitry. for that you most likely will have to disassemble your phone and clean the board with 90%+ Isopropyl alcohol and a soft brush. Check for corrosion and damaged connectors/components. Again posting some images may help to identify any damage. The other issue with this phone is that schematics etc. are very hard (if at all) o obtain.
Add a comment
Add your answer
Shoaib Quraishi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,491
